Just changed tie-rod end
Old Oct 22, 2012 | 10:11 PM
arnonefrank13's Avatar
arnonefrank13
Default Just changed tie-rod end
Its a bitch unless you have a tie-rod puller. thank god my friend down the road did. I tryed everything to get it off the nuckle...you have to use a puller.....count your rotation when taking it off so the new one is in the same place.... my back hurts...
Old Oct 22, 2012 | 11:32 PM
Moparkyle's Avatar
Moparkyle
A big hammer usually does the trick too
Old Oct 23, 2012 | 12:15 PM
TejasMtnBiker's Avatar
TejasMtnBiker
PB Blaster soaked over night is the trick, I've not had to hammer one thing since I started using PB, thanks these forums here
Old Oct 23, 2012 | 03:39 PM
AnthemBassMan's Avatar
AnthemBassMan
-Yep. Back the nut off until it is flush with the threads on the old tie rod then give it a whack with a hammer. Usually only one or two hits is all it takes.
L8R,
Matt
Old Oct 23, 2012 | 07:52 PM
arnonefrank13
not this one..... it was on there . but ya i bet pb blast woulda helped.. thanks guys!
