Tranny, Torque Conv, who knows..??
Old Oct 27, 2012 | 12:55 AM
arnonefrank13's Avatar
arnonefrank13
Question Tranny, Torque Conv, who knows..??
Ok, So Its an automatic tranny with 70k and I was told a new torque converter. Anyways say I'm going 40mph for a mile then I let off the accelerator( do not brake - let it coast) and around 25mph I can feel it kick down and slow me down.... what is that? and is that normal? The car is a SOHC and has new timming belt and acc. belts..
Old Oct 27, 2012 | 01:24 AM
fhadso's Avatar
fhadso
Sounds more like a TCM problem.
Old Oct 27, 2012 | 03:53 PM
arnonefrank13
transmission controll module?? where is it... i know theres a plug/wires on my tranny that looks like is pluged with a cap or end...but it is pluged in...hmm..
Old Oct 27, 2012 | 10:22 PM
fhadso's Avatar
fhadso
Well, the atx in our cars is definitely not my expertise. I drive a standard :P. But things to check would be tranny fluid and quality (should be cherry red and translucent), shift linkage, the cable that goes from your throttle body to your tranny (I can't think of what it's called), and if you have any error codes.
To check for codes, put the key in with the door shut and turn the key from off to on three times (on-off-on-off-on). Write down any P codes it might have. Or take it to an autozone to see if you have and TCM codes stored. Like I said, I have an mtx, so I'm not too familiar with FWD atxs.
Old Oct 28, 2012 | 12:17 AM
arnonefrank13
fluids fine....dad says its kicking down gears. u cant feel it...only hear it.
Old Oct 28, 2012 | 03:26 AM
darthroush's Avatar
darthroush
Section Moderator
Might be a temporary spazzing out of the TCM/Solenoid Pack, or you just might need a new solenoid pack.
Old Oct 29, 2012 | 03:12 PM
arnonefrank13
it got a new shift selinoid and gaskets and filter when it was installed....15k ago
