Weird Shifting issue
Old Oct 29, 2012 | 10:44 AM
jeremy_mcelwain's Avatar
jeremy_mcelwain
Exclamation Weird Shifting issue
Never dealt with auto's before, always 5 speeds...so this is a weird one for me.
Transmission shifts and runs just fine, no CEL or codes at all. But shifting from what I think is 2nd to third, it sometimes "slams" into gear. Other times, when I pull up to a stop, it won't shift into 1st and just sits in neutral - like it started to shift but stopped.
Thought my solenoid was bad, but tested it and all resistance levels are great. Replaced fluid and filter, which actually did help - but this one won't go away.
My thoughts, is it one of the 2 sensors on the front of the tranny? Input and output speed i believe?
Or...and I hope is not the case...is the trans shot.
Please help guys!
2002 Neon ES 181k miles
Old Oct 29, 2012 | 08:31 PM
jeremy_mcelwain
UPDATE
New solenoid, input sensor, output sensor - still does it but nowhere near as often or hard.
Solenoid was clicking and ticking before, now its not - so I take that as an improvement.
Any thoughts on whats next? TCM? Reflash?
Old Oct 29, 2012 | 11:01 PM
cheapez's Avatar
cheapez
The problem with your trans is fixed by most people by replaced the control solenoid. These people get code p0700, but you don't.
Let me know how you fixed this problem.
I'm having a problem with my car shift hard into 3rd. It shifts smooth in all gears, but whenever it downshifted from 3rd to 2nd, if I give it gas, the car will gain some speed and shift hard into 3rd.
Like you, I don't get any code.
Old Oct 29, 2012 | 11:16 PM
cheapez's Avatar
cheapez
On Chrysler trans, there a relearn procedure.
You don't need to relearn the tcm if you have only replaced the solenoid, input sensor, and output sensor.
Reflash if you have the newest update.
I heard there are newer updates for the tcm over the years.
Old Nov 17, 2012 | 10:12 AM
jeremy_mcelwain
UPDATE
So ok, here is what I have done so far.
1. New fluid and Filter
2. New Solenoid
3. New input sensor
4. New output sensor
Pulled TCM and it has a sticker on it saying it was updated in '03 (car is an '02)
Until the motor warms up, the tranny shifts fine. ONce warm, it shifts pretty darn hard between 2nd and third gear only. No leaks, clicks from the solenoid, or any other symptoms. No metal in the fluid either.
THoughts? I'm at a loss...trying to decide if the $100 reflash is worth the gamble...or does that sound like its it?
