2002 dodge neon help
Old Nov 3, 2012 | 10:31 AM
mgw234's Avatar
mgw234
Originally Posted by darthroush
Can you describe the problem in more detail? What do you mean it stops by itself? Your cruising at 55MPH and the car just slows to a stop unless you floor it? The car just won't go forward from a stop? What's going on exactly when the car is "stopping?" Is the engine lagging? Does it feel like the brakes are stuck?
it only does this when i start to drive, only going like at 10mph, once going at this speed it stops when I first turn on the car. it only happens when I do not use the car for a while. like a couple of hours. it seems to only happen when the engine isn't hot enough. but when it is it goes perfectly. I think this is a transmission problem. My original thought is that the fluid isn't going into the gas pedal enough. which is why I have to push on it harder to get it going.
Old Nov 3, 2012 | 12:17 PM
cheapez's Avatar
cheapez
Did the engine stall at all? Running rough, or anything like that?
Your car is supposed to shift into 2nd gear at 10 mph. When it shifts, can you feel it?
I still don't know if it's the problem with the engine, or the transmission.
It will help if you can describe things clearer.
Old Nov 3, 2012 | 01:36 PM
mgw234's Avatar
mgw234
I start the car, then i go into reverse to get out of my parking space, then I shift into drive, and then the car does not move when I press the gas pedal, so when I press the gas pedal harder, the car slams into drive and then it works fine. and then it does the same thing if I leave the car off for a couple of hours.
Old Nov 3, 2012 | 02:04 PM
arnonefrank13's Avatar
arnonefrank13
maybe fuel filter....
Old Nov 3, 2012 | 05:42 PM
cheapez's Avatar
cheapez
Sounds like a transmission problem to me.
Hard to diagnosis with out taking it out for a spin.
Old Nov 4, 2012 | 05:33 PM
darthroush's Avatar
darthroush
Section Moderator
My car does that at random every now and then. No clue why. I'd venture to guess it's something to do with the solenoid pack, but I've got a new one as well as a TCM update. Not sure what the deal is.
Old Nov 5, 2012 | 08:55 PM
mgw234's Avatar
mgw234
where is the solenoid pack?
Old Nov 5, 2012 | 10:45 PM
darthroush's Avatar
darthroush
Section Moderator
Front, top of the transmission.
Old Nov 6, 2012 | 12:41 AM
mgw234's Avatar
mgw234
alright thanks, I will check out the solenoid, and clean my transmission. I haven't cleaned it in a while. See what comes up. Thank you.
