Low idle after vehicle warmed up
Old Nov 3, 2012 | 10:23 PM
silversx33's Avatar
silversx33
Default Low idle after vehicle warmed up
Hey guys hows it going?
I am having a low idle on my 2004 dodge sx2.0 sport when vehicle is warmed up the idle sits between 500-600rpm the steering wheel begins vibrating and you can hear a rattle or vibration coming from the engine under the hood.
I have had motor mounts replaced 1 yr ago
I have changed my spark plugs wires to ngk
I have put brand new champion plugs gapped at 35
I have replaced the TPS & Idle Air Valve didnt make any change
I have cleaned the Throttle body
When I turn on my AC my idle rises at 900RPM and vehicle runs fine but its now winter time I cant use the AC during winter to get rid of that problem.
This issue btw doesnt happen all the time which im at the point now I have no idea what the problem is
I put lucas fuel treatment in gas tank as well changed engine oil.
Im really puzzled any help would be greatly appreciated!
Thanks
Old Nov 3, 2012 | 10:24 PM
silversx33's Avatar
silversx33
If I have vehicle in park or reverse or Netural the idle rises and its fine soon as its in drive thats when it happens
silversx33's Avatar
silversx33
I have a picture of where the idle sits at but I have no clue how to post a picture
Old Nov 3, 2012 | 10:31 PM
silversx33's Avatar
silversx33
Old Nov 3, 2012 | 10:34 PM
ksuchewie's Avatar
ksuchewie
Mine does this as well. Today I adjusted the screw on the TB to open it a bit during idle to see if that helps.
Old Nov 3, 2012 | 10:54 PM
silversx33's Avatar
silversx33
Hey buddy can you show me a picture of where it's located and also what idle i should be putting it at?
I greatly appreciate it I have done everything today and I'm just real bummed out I've ran out of ideas!
How's your vehicle running now?
Old Nov 3, 2012 | 11:02 PM
buddhaman's Avatar
buddhaman
Did you disconnect the battery before you changed the sensors?
Old Nov 3, 2012 | 11:05 PM
silversx33's Avatar
silversx33
No buddy was I suppose to?
Old Nov 3, 2012 | 11:06 PM
silversx33's Avatar
silversx33
I have no check engine light nothing at all
Old Nov 3, 2012 | 11:10 PM
ksuchewie's Avatar
ksuchewie
I'll try and get a picture of it tomorrow. It is on the underside of the throttle body near the throttle cable. It's a brass colored 4.5mm screw if I remember. Tighten it (clockwise) to increase the idle. I had some errands to run after working on it so I haven't had a chance to see if it has made a difference or not. I'm just going to slowly keep tightening it to raise the idle to about 650/700 if I can.
