2003 Dodge Neon SXT Idle Problem
Old Dec 10, 2012 | 08:45 PM
Ryan.youngii's Avatar
Ryan.youngii
Default 2003 Dodge Neon SXT Idle Problem
I have a 2003 Dodge neon SXT manual, it has 196k on it also has exhaust has stock intake but the filter cover is off and a cheap CAI filter is in there also has MSD ignition and wires. It has a check engine light that was on for TPS and it used to idle at 3k RPM's. I went ahead and replaced the sensor and turn off the Engine light. I have driven about 250 miles still no check engine light. When I first start the vehicle is idles fine but when warm it like to go from 1500-2000 and sometimes when cold if I put my foot on the brake it will also Idle to 2k then back down when I let off the brake. Any recommendations?
Old Dec 10, 2012 | 09:43 PM
buddhaman's Avatar
buddhaman
Sounds like a vacuum leak to me. Get a can of starting fluid and spray around your vacuum lines with the engine running. Spray a little at a time and if the idle changes when you're doing it, you found your leak.
Old Dec 11, 2012 | 06:43 PM
Ryan.youngii
Thanks I will check that out
Old Dec 12, 2012 | 02:38 AM
arnonefrank13's Avatar
arnonefrank13
make sure you do the spray test when the ENGINE is COLD. you can burn your car down with that fluid.
Old Dec 12, 2012 | 11:02 AM
TejasMtnBiker's Avatar
TejasMtnBiker
hehe nothing like an Either fire ball "poof" to give your face a quick close shave
Old Dec 16, 2012 | 08:00 AM
hinkel's Avatar
hinkel
block off your brake booster and try it, had one car the brake booster diaphram ripped and caused the same problem
