2000 Neon will not start - please help
Old Sep 9, 2005 | 12:29 AM
2KTXneon's Avatar
2KTXneon
Default 2000 Neon will not start - please help
My 2000 Neon died a couple of days ago. It will not start. Almost half a tank of gas. Cranks fine. Battery is good. I've ohmed out the fuses in the engine compartment and interior panel and swapped the relays around, no help. I've checked the fuel pump; I can hear it pressurize and I verified pressure...44 psi at the rail. The car will start using starting fluid so the spark side of the equation seems to be in order. I tried to listen for the fuel injectors but cannot hear them (may be due to being drowned out by attempted starting). Any suggestions are appreciated.
Old Sep 9, 2005 | 01:39 AM
DeoN44's Avatar
DeoN44
Default RE: 2000 Neon will not start - please help
check your fuses, especially the one to the starter
Old Sep 9, 2005 | 09:12 AM
01NeonR/T's Avatar
01NeonR/T
Any codes being thrown?
Old Sep 9, 2005 | 10:59 AM
2KTXneon's Avatar
2KTXneon
I have not checked codes yet. I will get a reader today and check them. Are there key-on key-off codes with a Neon or is a reader the only way to retrieve them?
Old Sep 9, 2005 | 11:32 PM
2KTXneon's Avatar
2KTXneon
I ran a scan and no codes came up.
Old Sep 16, 2005 | 09:04 PM
jordan_davis's Avatar
jordan_davis
"car will start using starting fluid" You crazy ************
EDIT - By passing filter and foul Language.
Old Sep 20, 2005 | 10:45 PM
Midnight SRT's Avatar
Midnight SRT
Nightly Creeper
ORIGINAL: jordan_davis
You need to watch your mouth. I have seen nothing but pointless, rude posts from you. Please stop.
