Spoiler
Old Dec 21, 2012 | 11:12 AM
jord712's Avatar
jord712
Default Spoiler
I would like to put a neon spoiler on my neon that did not come stock with one. And I am just wondering what hardware I need to get? Also I don't know if it would be possible, but if possible could someone put up some sort of a stencil as to where I should drill the holes?
Old Dec 21, 2012 | 02:23 PM
fhadso's Avatar
fhadso
Well, I believe your best bet would to get a trunk that matches your color and has a spoiler already on it. Any trunk from any 2nd gen neon will fit.
Old Dec 21, 2012 | 07:57 PM
richards83's Avatar
richards83
If you open the trunk and look at the bottom side, you should see two holes in the framework on each side where the nuts would be on the spoiler studs. If you drill your holes directly in the center of those holes you should be good. The spoiler is secured with four 10mm nuts. I do agree with fhadso. It would be easier if you can find a trunk lid to match your car. When I'm lucky enough to find a spoiler at the junkyard I get them for $25, but have to spend another $30 for paint to match the car.
Old Dec 21, 2012 | 08:01 PM
Neonewbie's Avatar
Neonewbie
I beleive they sell matched color in spray paint
They go for I believe $8
You could do the whole spoiler with the one can.
Old Dec 21, 2012 | 09:07 PM
TaterTodd's Avatar
TaterTodd
Here's a spoiler that would look nice ... http://www.modernperformance.com/pro...erior_exterior
Old Dec 22, 2012 | 09:43 AM
jord712's Avatar
jord712
I'm planning on putting the big srt-4 spoiler on I just need to find a decent deal on one
Old Jan 30, 2013 | 05:39 PM
V8power1990's Avatar
V8power1990
I put a spoiler on my thunderbird and i measured the spoiler on the back and put dots with a sharpie of where the bolt studs were on the decklid. I then drilled out the holes and it lined up great just take your time measuring it up because once you drill once thats it.
