finally made my short ram air box mod
Old Jan 8, 2013 | 11:13 PM
Neonewbie's Avatar
Neonewbie
Default finally made my short ram air box mod
I modded my airbox then only thing is I cut one of the screw slots that attach to the battery plate which i figured would be okay.
Its much sturdier now and may help keep some heat away from the tube / filter.
Looks pretty generic though since it is just a cut box.
Old Jan 9, 2013 | 01:33 AM
arnonefrank13's Avatar
arnonefrank13
i have the same setup, exept i dont have the blue hose i have a lil breather filter on my valve cover.
Old Jan 9, 2013 | 01:40 AM
arnonefrank13
where did you get the tube with a hole in it at (the tube the valve cover hose connects too)?? what type of air filter is that and what was the cost??
Old Jan 9, 2013 | 09:39 PM
Neonewbie's Avatar
Neonewbie
share pics of yours and I will share my info =P
I will tell you I just would like to see yours.
I paid $25 for the blue tube, the metal tube with air feed line which is lame plastic, the blue hose and a paper filter.
My care has vibration and i think that helped cause the rubber base at the bottom of the filter to get loose. So to be safe I went and picked up an oiled spectre inverted cone filter, I believe it was $25
