P0441
Old Feb 22, 2013 | 01:08 PM
brentb31's Avatar
brentb31
Default P0441
Daughter brought home her 2003 SXT for the weekend. It shows code P0441. Also, she said the oil light is on and dings. I checked the oil level it is way over. She said she has added about 3 quarts over the last couple of weeks without checking the level. She said the car started running real sluggish right before she pulled in the driveway. I'm looking for some guidance on where I should start checking.
Any help provided is greatly appreciated.
Old Feb 23, 2013 | 03:09 PM
go-part's Avatar
go-part
Former Vendor
http://engine-codes.com/p0441_dodge.html
The CEL is brought on by Evap issues.
The oil light is being set poff due to the car having to much oil and it foaming up, causing a drop in oil pressure.
http://www.ehow.com/way_5908704_do-o...d-car-oil.html
Drain the oil asap.
Old Feb 24, 2013 | 08:29 AM
brentb31's Avatar
brentb31
Drained the oil, was way over. Ran the car around the block, whenever it goes to shift from first to second gear and second to third the car bogs down, could the code P0441 cause that?
Old Feb 24, 2013 | 04:14 PM
darthroush's Avatar
darthroush
Section Moderator
No, but old plugs and wires could. How many miles on each? Plugs should be changed every 30K and wires every 60K, or, every other plug change.
Old Mar 6, 2013 | 11:26 AM
brentb31's Avatar
brentb31
Thanks for the input, car is due for a tune up. Plugs, wires, and air filter will all be changed shortly.
