cold air intake
Old Feb 27, 2013 | 09:37 PM
6t8n8's Avatar
6t8n8
New Member
Default cold air intake
I installed a cold air intake on my 2004 sxt neon. Now when i start the car it revs up to 3,000 rpm. Anyone know what the problem might be?
Old Feb 28, 2013 | 02:44 AM
Ryca105's Avatar
Ryca105
Did you forget the vacuum line?
Old Feb 28, 2013 | 09:31 AM
6t8n8's Avatar
6t8n8
New Member
No, everything is hooked up.
Old Feb 28, 2013 | 05:51 PM
darthroush's Avatar
darthroush
Section Moderator
The TPS and IAC connectors are connected firmly?
Old Feb 28, 2013 | 10:33 PM
arnonefrank13's Avatar
arnonefrank13
you have a vaccum leak prolly the lil hose right under the IAC valve. OR theres one on top of the throttle body right above the IAC ( more twords the radiator ). Or you valve cover/pvc hoses....maybe everything isnt buttond up enough..
Old Mar 1, 2013 | 11:08 AM
TejasMtnBiker's Avatar
TejasMtnBiker
speaking of top of the throttle body mine has a vac plug cap on it with a zip tie, when I pulled that motor from a junker I've never took the time to research where/what it should be plugged into
