belt tensioner pully
i have a 2000 neon can anyone tell me how to change the belt tensioner pully or idler pully please? this is for the power stearing and a/c belt. thank you
Its a tuff job. you need good tools and at least 2 jacks and a 55torx socket. there are 2 18mm torque strut bolts and 1 center mount t55 bolt. then theres 3 or 5 13mm bolts to remove the power steering unit. then theres 3 15mm engine braket/tensioner pulley bracket bolts. this job involes many up and down engine movements to remove certian bolts at certian times of the job. If your good with tools its a 2 hour job. If not your lookin at problems( like breaking the timing cover or missaligning the engine mounts. ) anyways you tube timing belt bracket video. I got a video on the R&R on the center mount. Goodluck
