code 2074
Old Apr 24, 2013 | 02:18 PM
mike L's Avatar
mike L
Default code 2074
I have fast and rough idle. I found online, to check the Map and TPS. Does that sound right?
Thanks again,
Mike
05 neon 2.0
P2074-manifold Pressure/throttle Position Correlation
CORRELATION - HIGH
FLOW/VACUUM LEAK
When Monitored: Engine Running, during all drive modes.
Set Condition: If vacuum drops below 1.5 Hg with engine RPM greater than 2000 RPM
at closed throttle.
POSSIBLE CAUSES
GOOD TRIP EQUAL TO ZERO
VACUUM LEAK
HIGH RESISTANCE IN MAP (K7) 5 VOLT SUPPLY CIRCUIT
RESISTANCE TO GROUND IN MAP (K7) 5 VOLT SUPPLY CIRCUIT
MAP SENSOR
HIGH RESISTANCE IN (K1) MAP SIGNAL CIRCUIT
RESISTANCE TO GROUND IN (K1) MAP SIGNAL CIRCUIT
HIGH RESISTANCE IN (K4) MAP GROUND CIRCUIT
PCM
TP SENSOR OPERATION
HIGH RESISTANCE IN (K6) TP SENSOR 5 VOLT SUPPLY CIRCUIT
RESISTANCE TO GROUND IN (K6) TP SENSOR 5 VOLT SUPPLY CIRCUIT
TP SENSOR
HIGH RESISTANCE IN (K22) TP SIGNAL CIRCUIT
RESISTANCE TO GROUND IN (K22) TP SENSOR SIGNAL CIRCUIT
HIGH RESISTANCE IN TP (K4) SENSOR GROUND CIRCUIT
Old Apr 24, 2013 | 02:34 PM
Ryan 20's Avatar
Ryan 20
I would check for vacuum leaks first, including the intake manifold and gasket.
You can spray some carb cleaner to help find where it's at.
Old Apr 25, 2013 | 04:45 PM
mike L's Avatar
mike L
Default Vacuum leak
Thanks it was a vacuum leak.
