Need some help!
Old May 2, 2013 | 11:54 PM
TejasMtnBiker's Avatar
TejasMtnBiker
what I mean is the actual jaws that grab the the lip, are the the same no matter what way you put them on? mine is shorter one direction and longer assembled the other direction sounds crazy but its the cheapest made crap, I think its for the alt pulleys to pull off actually not for the harmonic, man that sucks sorry your having so much trouble with it.. tried a different puller from another auto place maybe?
Old May 3, 2013 | 08:46 PM
Neonproject12's Avatar
Neonproject12
I've tried every way switching them around and trying to do all the crazy things I could think of. & yeah I tried 2 times from advanced auto parts and one from autozone. From autozone it was the actual Chrysler puller lol just my luck
Old May 4, 2013 | 10:07 AM
TejasMtnBiker
lastly I guess you can try heating it up with a hair dryer not a torch... might take 30 mins of heat to get it to expand with heat,, but if your comfortable and can solder circuitry with a torch that will free it and have your fire extinguisher ready... dont heat directly on the crank end more focus on the outer edge where the pulley meets the crank if that makes sense.. otherwise dont attempt
Old May 5, 2013 | 01:54 AM
darthroush's Avatar
darthroush
Section Moderator
Perhaps I misunderstood one of the posts, but just to make sure: when using the Chrysler puller and insert, you had the balancer bolt removed, right? When using the generic pullers, you had the balancer bolt installed, right? Also, you are putting the jaws in the center of the pulley, not on the outside, correct?
Old May 5, 2013 | 10:37 AM
Neonproject12
Idk if I trust myself to use heat or torch so I might stay away from that idea & yes I took the bolt out while using the pullers. All of the pullers were the same pretty much just the only thing was the Chrysler puller did not have the balancer in the kit . Yes I am putting the jaws in the middle not the outer rings
Old May 6, 2013 | 01:57 AM
darthroush's Avatar
darthroush
Section Moderator
The Chrysler puller is the only one in which you take the balancer bolt out because it has the extension, or it's supposed to, that replaces the bolt. If you didn't have the extension, you didn't get the whole Chrysler puller kit. For the aftermarket, generic 3-jaw pullers, you have to have the bolt in part of the way. If the bolt isn't there, there is nothing for the puller to push against and subsequently, there is going to be no force to pull the balancer off. The pullers are basically working against themselves.
Old May 8, 2013 | 12:22 PM
Neonproject12
Balancer bolt you mean the one on the puller? And it had the extension ( long skinny rod for in the middle right? )
Old May 8, 2013 | 10:34 PM
TejasMtnBiker
no he mans the actual balancer bolt stays in part way so the 3 jaw puller's long skinny bolt can press against it, thus the jaws grab and forces pressure on the balancers bolt head which pulls the balancer loose. Dont mess up the crank threads make sure to have the balancers original bolt 1/2 way in. hopes this makes sense
Old May 9, 2013 | 09:10 AM
Neonproject12
Now I understand, it makes more sense now seems like it will work but hopefully luck is on my side when I try that
Old May 9, 2013 | 11:48 PM
TejasMtnBiker
wish you were in Dallas I'd had it off for ya =)
