High proformance neon misfire
OK first the engine build
04 neon 2.0L 5spd
- hand ported factory head, 3 angle valve grind.
- reground cam shaft (95 spec or better)
- 2010 rt flat top pistons
-.035" off the head
- 11.5:1 cr
-cold ram air intake
- factory exhaust manifold
-3" exhaust
The issue
at idle# 2 cylinder is not firing ( pull the wire no rpm change)
it starts firing at 2000 rpm
- we have spark and fuel
compression is even across the board like 75 lb if i recall
i am going crazy any ideas ???????
help pls
04 neon 2.0L 5spd
-.035" off the head
- 11.5:1 cr
-3" exhaust
The issue
help pls
