Specific Rim Offset For My 2004 Dodge Neon
Old May 14, 2013 | 03:19 PM
Orlando_719's Avatar
Orlando_719
Default Specific Rim Offset For My 2004 Dodge Neon
Hello everyone first timer here, I purchased a 04 Dodge Neon with some ugly rims (Konig) now I tried removing these rims and putting some steelies with the similar tire size. When I switched the tires out the front brake calipers were rubbing on the inner rim. So had to replace the old rims and wanting to know what is the size and offset of the OEM rim for 2003-2005 Neon, and if it would be possible to throw some rims from some late model Neon's on mine.
Old May 14, 2013 | 04:28 PM
TejasMtnBiker's Avatar
TejasMtnBiker
Does that steel rim have the big holes like golfball size? If so that's for the old neon, smaller holes will be $0.25 quarter size or if there are no holes you have toyota steels, can you find any stamped numbers or letters on the steel oen you have? I wish I knew the offset hopefully someone will chime in
Old May 14, 2013 | 04:56 PM
darthroush's Avatar
darthroush
Section Moderator
AFAIK, the stock offset for all non-SRT Neons is +40mm. Yes, you can fit any non-SRT Neon wheel onto a non-SRT Neon.
Old May 14, 2013 | 06:45 PM
Orlando_719
Thanks well I found another Dodge Neon owner I think he said the year of his was 99-01 and was willing to swap my rims for his steelies plus $ on his side, I just want to be able to do a simple swap without worrying about the rims not being able to fit. (Wish all steallies had a size stamp) The steelies I first tried were I believe to be off a 2005 Chevy cavalier.
