Need help, don't know what else to do!
Old Jun 12, 2013 | 09:06 PM
MichaelRauscher's Avatar
MichaelRauscher
Default Need help, don't know what else to do!
Hello!
I have been spending the last few days trying to get my dome light to turn off and the DOOR display on the dash in my 2000 Neon XL
There don't seem to be a switch on the dash or anything so its not that..
I have fixed many door switches over the years in Jeeps so I figured that was probably the issue.
I took each door switch out one, by one, light still stays on and says DOOR
Then I said F it and took them all out.. Light stays on, dash says DOOR.....
Then I noticed when you open the driver door with the lights on it dings. So I hooked each switch up to the drivers door one by one and they all DING then when I press the button they all stopped dinging.. That means they all are working.
I'm stumped..
Old Jun 13, 2013 | 02:38 AM
darthroush's Avatar
darthroush
Section Moderator
Maybe I'm overthinking this (just got off of work, I'm always in overdrive this time of night), but if the driver's door wiring was good but another door's was bad, and all of the switches are good, they'd all test fine on the driver's door, yeah? Have you checked the wiring on the other three doors?
Old Jun 13, 2013 | 11:43 AM
MichaelRauscher
It's odd because I'm actually getting 12volts through to my door switches which I'm sure it's supposed to be just a ground. So there should be no power coming from them.. All wiring seems totally fine though. Took up carped and panels to follow wiring and it all look really good
Old Jun 13, 2013 | 12:06 PM
TejasMtnBiker's Avatar
TejasMtnBiker
does the multifunction switch work 100%?
