05 neon trouble overheating
Old Jun 22, 2013 | 10:47 PM
Jere85's Avatar
Jere85
Default 05 neon trouble overheating
So my 05 neon sxt is loosing coolant not sure where I've put a new radiator cap on put a new t stat in and done a compression check and I'm still loosing water I need some ideas it has almost 100k on it thanks
Old Jun 23, 2013 | 06:15 AM
darthroush's Avatar
darthroush
Section Moderator
If it's not leaking from a hose or the radiator, check your transmission fluid ASAP before driving the car again. If the transmission fluid looks like a milkshake, you've got a problem.
Old Jun 23, 2013 | 04:37 PM
Jere85's Avatar
Jere85
tranny fuild still looks pretty red and its not leaking on the ground the water pump is working fine im kinda stumped
Old Jun 23, 2013 | 04:42 PM
darthroush's Avatar
darthroush
Section Moderator
Does you engine oil look diluted at all? Have you stuck a large piece of cardboard under the car overnight to see if there is any leaking anywhere? I've spotted leaks on cardboard where I couldn't see anything on pavement.
Old Jun 23, 2013 | 09:10 PM
xarkhun's Avatar
xarkhun
the heater core could be leaking but you would probably notice a wet floor
Old Jun 23, 2013 | 09:51 PM
Jere85's Avatar
Jere85
floor is dry and the engine oil looks good and isnt raising
Old Jun 23, 2013 | 09:55 PM
Jere85's Avatar
Jere85
also i park in a garage so seeing leaks is pretty easy
Old Jun 25, 2013 | 12:08 PM
Jere85's Avatar
Jere85
Seems like all my water is being pushed into the boost bottle but not returning to the radiator any ideas
Old Jun 25, 2013 | 03:27 PM
darthroush's Avatar
darthroush
Section Moderator
Bad radiator cap.
Old Jun 25, 2013 | 07:10 PM
Jere85's Avatar
Jere85
I just replaced it a week ago
