horn not working
Old Jul 10, 2013 | 10:44 AM
jamesneon2003's Avatar
jamesneon2003
Smile horn not working
my horn not working,i swaped a relay fuse from a working horn form neon still didn't work any ideas
I press the horn but nothing at all
Old Jul 10, 2013 | 05:26 PM
xarkhun's Avatar
xarkhun
could be a short in the wiring either in the steering wheel or at the horn itself or just a loose connection somewhere
Old Jul 10, 2013 | 11:53 PM
sbhawaiian's Avatar
sbhawaiian
If you are not getting voltage at the horn and your fuze is good I would check the clockspring located in the steering column. The round piece of plastic controls the airbag and horn. The contacts on it can wear out. you will have to pull the wheel and remove the airbag. disconnect battery and let sit for a while (Be careful).
Old Feb 21, 2021 | 08:45 PM
Richard Feury's Avatar
Richard Feury
Default Horn switch. Help!
I finally got around to troubleshooting the horn stuck on problem.
I removed the airbag, removed the horn switch and installed the horn fuse.
Horn does not blow!
Checked by grounding wire to steering wheel and it blew.
Does anyone have an old airbag that they can take the switch out of and sell it to me.
I can’t find a new one anywhere without purchasing a complete airbag.
Help
Thanks
