Timing belt noise, normal?? with video
Old 09-03-2013, 10:13 PM
frankarnone70's Avatar
frankarnone70
frankarnone70 is offline
Default Timing belt noise, normal?? with video
Hello, My car is a 2002 dodge neon ES with 161k. I had a weird noise coming from the mechanical tensioner, so I decided to replace it. Also replaced water pump and the timing belt. The belt and tensioner are the Gates brand. The water pump is a TRUE Flow. lifetime warranty. Timing is right on and the tensioner is in the window ans everything is torqued down. Does this engine sound "normal" to you guys? Or do timing belts have "break in" time/noise??.... I donno. Tell me what you think and thank you.
http://www.youtube.com/watch?v=ml_20...ature=youtu.be
Old 09-11-2013, 12:59 AM
frankarnone70
Anyone wanna share some of there thoughts?
Old 09-11-2013, 03:37 AM
JoseyWales's Avatar
JoseyWales
JoseyWales is offline
two things,cheap belt or you got the tentioner to tight.
Old 09-11-2013, 11:48 AM
frankarnone70
Gates belt and tensioner is in the window. I think it's the timing cover rubing the tensioner
Old 09-11-2013, 12:14 PM
JoseyWales's Avatar
JoseyWales
well I had a 87 plymouth turizmo with a 2.2 when id replaced that timming belt it made the same noise ..it turned out I had it way way tooo tight..if your with in the window..i would just live with that sound then..
Quick Reply: Timing belt noise, normal?? with video
