washer pump not working
Old Oct 3, 2013 | 03:33 PM
burghduff_18's Avatar
burghduff_18
Default washer pump not working
I have a 2000 dodge neon it's my wifes car. the washer pump does not spray i have checked fuses. no fuses are bad. i have replaced the washer pump and still nothing. what would cause it to get no power? could the wiper switch on the steering column be bad? or is there a relay that has gone bad?
Old Oct 3, 2013 | 10:34 PM
darthroush's Avatar
darthroush
Section Moderator
Are any of the washer lines broken (i.e.- the fluid isn't making it to the nozzles)? ETA: I see you say there is no power? Have you made sure the pump is getting power with a DMM or test light?
Old Oct 8, 2013 | 12:22 AM
sbhawaiian's Avatar
sbhawaiian
Pull the unit out and test the motor directly. I have changed pump motors on several types of cars and it was not hard at all. I also got the parts from O'reillys or NAPA.
