Need help with knock sensor
Old Oct 29, 2013 | 02:47 PM
thisdamnneon's Avatar
thisdamnneon
Default Need help with knock sensor
I am almost done putting my neon back together but I cant remember where the knock sensor gets connected to on the block. There is also one more connector that I cannot find where it goes either. Here are the pictures. I have a 2005 neon sxt automatic
Old Oct 29, 2013 | 02:55 PM
frankarnone70's Avatar
frankarnone70
Map or access stuff. I know that the harness that slides between the intake is for the starter/ map/knock/ac
Old Oct 30, 2013 | 08:44 AM
richards83's Avatar
richards83
There should be a bolt hole in the block right next to the dipstick for the knock sensor. The other connector I believe is for the MAP sensor in the intake manifold.
Old Nov 9, 2013 | 05:13 AM
thisdamnneon
Found where the knock sensor goes (thank you richards83). The other one is connected to the crank angle sensor. Purrs like a kitten now.....but doesn't want to move.
