Slight issue after cleaning IAC valve
Old Dec 5, 2013 | 11:23 AM
chrisa0194's Avatar
chrisa0194
Default Slight issue after cleaning IAC valve
Before I cleaned the IAC the car would idle heavy and would hesitate for ~2 seconds on startup. It seems the idling issue has been solved, but on startup the rpms will drop to 400 or 500 for maybe half a second before returning to normal (Also there is no more hesitation while starting up--the car starts normally and then drops the rpms for a split second). Seems to be the only issue but I also haven't had a chance to go cruising just yet.
EDIT: 2000 neon ES
Old Dec 18, 2013 | 10:05 PM
sbhawaiian's Avatar
sbhawaiian
I cleaned my 2000 also and it ran rough after re-installing. I was thinking of replacing it but the part goes for $75 to $100+. I bought myself a code reader for xmas and will see what it says. I also read something about the needle plunger moving when plugged in to test if it's working or not. Good luck Richard
Old Jan 3, 2014 | 12:14 PM
TejasMtnBiker's Avatar
TejasMtnBiker
any luck yet on your fix?
Old Jan 4, 2014 | 12:44 PM
sbhawaiian's Avatar
sbhawaiian
Code reader said "no codes". One of the biggest issues on the forum because of the many possibilities to look at. So I'm back to square 1 again. Will look at motor mount alignment and IAC again when I get a chance.
