03-05 neon r/t heads
Old Oct 12, 2005 | 03:42 PM
FoutchSXT19's Avatar
FoutchSXT19
Default 03-05 neon r/t heads
Would it be a good idea to swap the heads from a SXT 2.0 16v to a R/T 2.0 Magnum and whats the difference between the regular 2.0 16v and the 2.0 Magnum
Old Oct 12, 2005 | 04:31 PM
casper's Avatar
casper
Default RE: 03-05 neon r/t heads
They are better heads. If you do swap them, it will give you a few more ponies.
Old Oct 13, 2005 | 03:40 AM
LowSlowNeon's Avatar
LowSlowNeon
It breathes a bit better, so you'll get a little bit more power. Don't expect a lot from it though.
Old Oct 23, 2005 | 01:09 PM
2point0togo's Avatar
2point0togo
The R?T head is ported nicley but you're going to want to get the R/T Intake Manifold or comparable manifold cause it wont do you much good to have the head ported without the extra air/fuel coming in.
