cai install
Old Oct 22, 2005 | 02:36 PM
LuBuSpeed15's Avatar
LuBuSpeed15
Default cai install
i am installing my cai and tb i have the tb in, but do you have to remove the tire and the mud guards in the wheel well to get the filter and pipe in? is there any write ups on the install thanks
Old Oct 22, 2005 | 05:18 PM
ViperGTS's Avatar
ViperGTS
Default RE: cai install
Check out the Neon section. That is where the best help is.
-Matt-
Old Oct 22, 2005 | 07:04 PM
MGDMike's Avatar
MGDMike
Welcome to DF!!
Old Oct 24, 2005 | 02:14 AM
LowSlowNeon's Avatar
LowSlowNeon
What kind of CAI is it? But yes, most likely you will need to remove the drivers side wheel (for more room), remove the plastic splash liner in the wheel well so you can get at the plastic air box that is in the bumper. I think if you take the wheel off and gain access to snorkel part for the airbox you'll see how to take it out. It comes out in two pieces and is held in there by 3 bolts I believe. Anyways, that should help ya. Its not too hard to do. Let me know, I can probably assist you. I just instlaled an intake on my car not long ago.
Old Oct 24, 2005 | 02:34 AM
Freerider's Avatar
Freerider
i just recently installed my Typhoon Intake on my 2004 SXT. At an easy pace, i took out the screws, set them in order in which they whent, took out the old intake system, jacked it up... took of the Drivers side wheel and took off the 2 screws that held the guard in place.
After that it was 2 screws i had to take out along with 2 of those plastic plug doohickies. It relinquished its old factory lungs after figuring out and getting it to come loose without forcing it out. The installation actually took a lot less time than that of just ripping out the old lungs.
DONT WE LOVE SURGERY?!
-Total time was about an hour and 45 minutes taking my time.
P.S. Yes, there are specific step by step instructions that came with mine (not to mention some tools to get the job done right) That was pretty cool of them to have done that.
