Turbo this upcoming spring
Old Oct 21, 2005 | 08:08 PM
04 mo neon's Avatar
04 mo neon
Default Turbo this upcoming spring
I have decided I dont care and i'm going to turbo my sxt. Not with a kit but i am going to order everything individually and try to squeek it under 1200, thats right 1200 dollars by my calc. Thats everything from the turbo (t3-t4 hybrid 25psi) to the pipes intercooler and fuel pump and connectors and lines. Also that includes the pistons and connecting rods. The only question I have is to run 25 psi which I wont be able to resist the only thing i need to make the motor handle that is rods and forged pistions right? If there is anything else I would need for (internal motor) parts so that the engine would handle it please let me know. Now with the larger torque converter and the turbotimer/fuel controller/boost controler (all in one modual i found for 300(so cheap)) the price comes to around 1600 in total but when you look at other kits and boost contollers u would be in the 5000-7000 dollar range so this is an awsome deal. All the parts are brand new and most are off ebay and the pipes and hardware I am buying and having bent up at local shops. SO I AM SO HAPPY i can't wait until this spring but I do need to know what interal engine mods I need done to handel approx. 25 psi.
Old Oct 22, 2005 | 01:51 AM
highrevr/tflea's Avatar
highrevr/tflea
Default RE: Turbo this upcoming spring
I deal in autoparts and I cant even get it that cheap....maybe you'll be pullin it outta a lotta junkyards or sumthin but if you can do it that cheap then kudos to you.......
Old Oct 22, 2005 | 03:13 AM
casper's Avatar
casper
That is really cheap. Are you getting an intercooler?
