2000 dodge neon .. idles fine ... bogs apone acceleration
Old Oct 8, 2014 | 08:24 PM
Tritium25's Avatar
Tritium25
Default 2000 dodge neon .. idles fine ... bogs apone acceleration
working on a dodge neon 2000 ... starts idles fine .. go to press on gas bogs down if I pump the pedle will increase rpm .. I have replaced plug and wires and pulled head and replaced all gaskets .. sent head to shop came back fine .. still having issues the the bogging down .. anyone help? fuel filter? MAP? sensers?
thanks
trit
Old Oct 8, 2014 | 10:53 PM
sxt112311's Avatar
sxt112311
well the first question here would be is it throwing any check engine codes if not you could just have a vacuum leak or your fuel pump is going bad or your filter is clogged or going
