throttle leak
Old Dec 18, 2014 | 02:48 PM
G SKI's Avatar
G SKI
Think its possible to drive a few minutes? With christmas , I cant get to it right a way.
Old Dec 18, 2014 | 03:06 PM
If it starts and runs, why not?
Old Dec 18, 2014 | 04:43 PM
G SKI's Avatar
G SKI
Probably will. Thanks for all the info. Enjoy the Holidays!
Old Dec 18, 2014 | 05:00 PM
darthroush's Avatar
darthroush
Section Moderator
Originally Posted by jkeaton
Kinda what I meant, IAC, was not sure if any other sensors are on it.
I meant about what he said about swapping parts if it would be cost effective. You are buying the complete TB either way, so unless they are going to credit you money for some springs and pieces of plastic, why bother? The sensors are a given though.
Old Dec 18, 2014 | 07:57 PM
Gotcha.
Old Dec 22, 2014 | 07:32 PM
G SKI's Avatar
G SKI
As I said earlier,I was looking for a cause of a code generated 1 week after getting car fixed at dealer for a bad p/s idler pulley. I know found the cause of the code a broken hose from valve cover to under intake manifold. Plus I now find that the mech for dealer put the accordian hose between throttle body and intake on backwards and did't tighten the clamps enough, car was reving higher which was what the code said. Also lost a captured nut on the air cleaner box and just stuck the screw in the hole. Unbalieveable!
Old Dec 23, 2014 | 04:49 PM
G SKI's Avatar
G SKI
Well I forgot about J B weld, at all. So for now its fixed ,just waiting for a code to resurface if at all. Thanks for the info.
