throttle leak
Old Dec 17, 2014 | 10:22 AM
G SKI's Avatar
G SKI
Default throttle leak
I broke the nipple cold weather off the throttle body under iac. Forgot what the cold weather does to plastic parts. what is the plastic housing called for the TB? Can't find it any where to buy w/o actual TB. Can i drive car till I fix this?
Old Dec 17, 2014 | 10:56 AM
What was attached to it? Does it still start, run?
Old Dec 17, 2014 | 02:51 PM
G SKI's Avatar
G SKI
It starts and runs. The hose goes to a hard plastic line towards back of car.
Old Dec 17, 2014 | 02:59 PM
Some vacuum or evap system line probably. I'm sure it will trigger the CEL soon enough.
Old Dec 17, 2014 | 04:57 PM
G SKI's Avatar
G SKI
Yeah I was thinking that was bound to happen. I went poking around there because a code
P0507 was stored. My luck. If I plug the hose, would that set off the cel as would the hole in the TB. What if I plug both, till I can get some tubing to fix this?
Old Dec 17, 2014 | 11:40 PM
darthroush's Avatar
darthroush
Section Moderator
The throttle body is a whole unit; there isn't just a "housing." I mean, yes, there is the housing of the T/B, but it's not a replaceable part that you can just buy. I know what line you are talking about, but without a Neon anymore, I can't go out and confirm what part you are specifically talking about. Sorry.
Old Dec 18, 2014 | 09:18 AM
G SKI's Avatar
G SKI
That's what I was thinking. Non replaceable.If I buy used, could I swap parts if cost effective?
Old Dec 18, 2014 | 09:58 AM
If its a part on the TB, buy a junk yard TB and swap the whole thing, Use your existing sensors though.
Old Dec 18, 2014 | 12:23 PM
darthroush's Avatar
darthroush
Section Moderator
If you are going to buy a used TB, why swap parts over? You'd just need to move over the IAC, I think that's about it. Everything else is going to be the same, but if you want to just because, by all means...
Old Dec 18, 2014 | 01:35 PM
Kinda what I meant, IAC, was not sure if any other sensors are on it.
