Would a 2002 PCM fit in a 2003?
Old Oct 26, 2005 | 01:32 PM
dajerm8's Avatar
dajerm8
Default Would a 2002 PCM fit in a 2003?
Both Neon's have the same engine and both automatic. But all I can find is a 2002 Neon PCM and was wondering if it would work in a 2003 Neon? Thanks for any help
Old Oct 26, 2005 | 08:16 PM
casper's Avatar
casper
Default RE: Would a 2002 PCM fit in a 2003?
I am not 100% sure, but I believe that you should be able to swap the PCMs. You might have to do some rewiring of sensors and stuff.
Old Oct 26, 2005 | 08:25 PM
GrApHite03's Avatar
GrApHite03
It will not work... It will fit, but it will not run your car. 2003+ has, what they call, a NGC ECU.
The 2003+ have a different crank trigger. Its a 13 tooth crank wheel... also the crank sensor is on the front side of the block, rather than the back on 95-02's.
Obviously you could make it work. You need a new crank, and you will have to drill and tap a hole for the crank sensor on the other side of your block.
k3v
Old Oct 26, 2005 | 08:36 PM
GrApHite03's Avatar
GrApHite03
oh, i almost forgot... The magnet on a 00-02 cam sensor is also different from the 2003+. That can be easily changed though... I'm running an 01 magnum head on my 2003. I just swapped the magnet from the stock head to the 2001.
k3v
Old Oct 26, 2005 | 08:37 PM
casper's Avatar
casper
Ok, guess I was wrong, lol. I knew about the NGC and some sensors being different, but not the crank sensor. Are you sure that its in a different place, the blocks are the same for 95- 05.
Old Oct 26, 2005 | 08:48 PM
GrApHite03's Avatar
GrApHite03
ORIGINAL: casper
absolutley, positivley... lol I have a 2001 block in my shop that usless to my 2003... I'll be building it for my 1st gen. If you get under a 2003 and take a look at where the 2002 and below's crank sensor normally is, you can see the spot where you would need to drill for the sensor. There is still a spot there in the casting. The blocks are identical... except for where the physical location of the sensor. Good 'ol DCX
k3v
Old Oct 31, 2005 | 07:42 PM
dajerm8's Avatar
dajerm8
I guess my next question would be is there any place to order one for less than what the dealers want. I have called a dozen salvage yards in my state and nobody has the part. I would rather have new or remanufactured if I can find one.
