Rear struts for 01 R/T
Old Apr 27, 2015 | 06:34 PM
Lambiotte's Avatar
Lambiotte
Default Rear struts for 01 R/T
I am having trouble verifying which struts to but online for this car. I am getting conflicting info on rear bushing sets as well. Should I be looking for SRT suspension parts? Many of the sites don't distinguish the R/T's on figment.
Old Apr 28, 2015 | 05:35 PM
darthroush's Avatar
darthroush
Section Moderator
R/Ts had Tokico struts (which should be the Tokico blues).
https://www.modernperformance.com/pr...pension_struts
http://www.andysautosport.com/produc...o__HB2234.html
http://www.andysautosport.com/produc...o__HB2233.html
I'm assuming you're looking for strut rod bushings?
http://www.andysautosport.com/auto_p...s/_/N-11m.html
Old Apr 28, 2015 | 09:54 PM
Lambiotte's Avatar
Lambiotte
Thanks...I am actually, ideally looking for full strut assembly due to time restraints and hassle factor.
Old Apr 30, 2015 | 01:46 AM
darthroush's Avatar
darthroush
Section Moderator
You'll pretty much be looking at take-offs then, unless you want new, in which case you'd buy regular Neon strut assemblies.
Old May 2, 2015 | 02:10 AM
Lambiotte's Avatar
Lambiotte
Default confused now...
OK, So I ordered replacement strut assemblies and the bolt pattern on the top of the strut mount is different than the units on the car. The unit on the car has 3 bolts that come through the tower, the replacements have 2 bolts, plus 2 smaller ones that look like they would be installed from the top down, but there would only be one hole?
Does anyone know if there are right before i send them back?
Old May 4, 2015 | 04:18 PM
darthroush's Avatar
darthroush
Section Moderator
If the mounts are all-together different than what came off of the car (four studs instead of three), then yes, they are the wrong ones.
Old May 17, 2015 | 09:27 AM
Lambiotte's Avatar
Lambiotte
Installed new struts yesterday...they apparently (aftermarket they) changes the top mount to be universal for both left or right side. The only strut assemblies or for that matter top rear strut mounts are now coming with the two inner studs as normal, but the third outer stud has been replaced with two threded inserts in which you put a 1 inch bolt coming down from the top.
There are two holes, one is used if the strut mount is on the right, and the other if you are using in on the left....
Be warned....what a hassle it is getting the third hole to line up....best bet that finally worked for me was to get the two studs in with the nuts treaded loosely, then get the bottom two bolts on the hub re-installed with the nuts treaded loosely, manipulate the entirre strut assembly around until you can jack it up and down and around until it lines up enough to get treaded.....be patient....THIS IS AN EASY CROSS THREAD SITUATION. Once the last bolt from the top is started, tighten it, then the stud nuts, then the hub nuts...
Now, go get an alignment!
Old May 20, 2015 | 03:13 PM
darthroush's Avatar
darthroush
Section Moderator
Interesting. I've never heard that about the "universal" strut mounts!
Old May 23, 2015 | 11:32 PM
Lambiotte's Avatar
Lambiotte
here is a pic of what it looked like..and worked.
