i installed a pcm for my 03 dodge neon now it doesn't start
Old 03-11-2017, 12:48 AM
JasonJsn02's Avatar
JasonJsn02
JasonJsn02 is offline
Default ECU change. No start
It started up for like 5 secs then it died i tried taking out the immubilizer it still doesn't start can someone help me please? i cant afford to get the car flashed back to my original vin number.
can someone help me out with the stressful issue with this car it started up perfect the first time but it died after 10 secs then the security light came on i wanna bypass it so the car can start and be back out on the road any suggestions??
Old 03-11-2017, 07:16 AM
jkeaton is offline
Dodge Forum Administrator
It needs to be flashed.
Old 03-11-2017, 10:03 AM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
Dodge Forum Moderator
Moved to 2nd Gen Neon forum.
Old 03-11-2017, 01:06 PM
TNtech's Avatar
TNtech
TNtech is offline
Site Moderator-Dodge Tech
Yep, the security has to be programmed. It's called a "PCM Replace" procedure in the scan tool.
Quick Reply: i installed a pcm for my 03 dodge neon now it doesn't start
