neon runs terribly
Old Mar 21, 2016 | 09:06 PM
Bill Schartiger's Avatar
Bill Schartiger
Default neon runs terribly
So i got this neon off my friend at work. It didn't run so I changed the spark plugs, wires, cam and crank sensor. I can get it to start after a lot of cranking. Idle is okay but when I try to accelerate it won't go over 4000 rpm when in drive and sounds and runs terrible when i'm accelerating. Lots of vibration too and I replaced the two passenger motor mounts. I can't figure whats wrong. After clearing the codes I still get crank or cam sensor code I can't remember which one it is.
Old Mar 22, 2016 | 04:20 PM
darthroush's Avatar
darthroush
Section Moderator
Did you replace the cam and crank sensors with Dodge units or aftermarket? These cars tend to like the factory pieces. Also, did you check all of the sensor wiring to make sure it isn't broken or grounding out? Is the cam magnet still solid and not broken? Did you use copper plug or platinum? Try to avoid platinum.
It sounds like it's still a sensor issue.
Old Mar 27, 2016 | 08:14 AM
* DB cooper*'s Avatar
* DB cooper*
I accidentally cut my map sensor wire once putting a new motor in and it sounds like thas what's happening here..
