2003 SXT no fire, at my ropes end...
Old Mar 27, 2016 | 02:27 PM
Michael Beckham's Avatar
Michael Beckham
Default 2003 SXT no fire, at my ropes end...
Hello everyone. I recently purchased my 2nd 2003 SXT neon. Gave 400 for it because the guy couldn't figure out why it wasn't firing. Car only has 91000 miles on it. I checked compression and got 125 psi across the board so I am ruling out any head issues. Anyhow, here's where I am at and still no go...
Here is some video:
Trying to crank it over: https://youtu.be/49-jpF_KQQE
ASD relay functioning: https://youtu.be/wbU-f5CAkSI
No anti theft/skim issues: https://youtu.be/OBer0J6Y560
I figure the engine light was blinking in the video from having plugged/unplugged skim unit.
Pulling codes: https://youtu.be/BDoRpUfDJAQ
Injectors pulsing: https://youtu.be/T3MdozgWXGw
Still not getting any fire. New crank and cam sensors, battery, coil pack, plugs and wires are good. I take it that since injectors are pulsing that crank and cam are in sync. The gas in it is good. Even if it were "bad" I don't believe it would prevent coil from firing. All the fuses and relays check out good, and I have removed, cleaned, and tightened all grounds. Also cleaned hookup at the PDC. Also checked continuity on all ground wires. Getting a little over 10 volts at coil pack plug. So I'm still at a loss. Thinking it may be malfunctioning ecm?
Any help suggestions would be appreciated. Thanks in advance.
Old Mar 28, 2016 | 01:34 AM
NovaSmith777's Avatar
NovaSmith777
yup thats wat it sounds like mine did that once got diffrent one ran like a champ
Old Mar 29, 2016 | 08:26 PM
darthroush's Avatar
darthroush
Section Moderator
The ECM sounds like that's about all that's left. I'd hate to say give it a go, but at present, I can't think of much else. If it isn't the ECM, it's usually the ASD, but you've checked that.
