2004 dodge neon motor problem?
Old Apr 15, 2016 | 06:18 PM
Gabb Marie's Avatar
Gabb Marie
Exclamation 2004 dodge neon motor problem?
I HAVE A 2004 DODGE NEON..
MY OIL LIGHT HAS BEEN ON SICE I HAD AN OIL CHANGE DONE, BUT IT ONLY CAME ON WHEN THE CAR HEATED UP. THEN COUPLE MONTHS LATER, MY CAR STARTED TO SHAKE, BUT IT WOULD ONLY SHAKE IN DRIVE. PUT IT IN NEUTRAL OR PARK OR REVERSE CAR STOPPED SHAKING. THE OTHER NIGHT I WAS DRIVING FOR ABOUT HOUR AND HALF AND MY CHECK ENGINE LIGHT CAME ON BUT NOTHING ELSE. PARKED THE CAR FOR ABOUT 3-4 HOURS, AND STARTED TO DRIVE BACK HOME. ENGINE LIGHT CAME BACK ON, AND SOUNDED LIKE IT WAS BACKFIRING. WELL WE GET ALMOST HOME AND THE CAR WONT GO OVER 40 MPH, AND IT WOULD REV UP ON ITS OWN WITH OUT TAPPING THE GAS. THEN GOING DOWN HILL IT WOULD KICK INTO GEAR AND JUMP UP TO 50 ON ITS OWN AND WOULDNT GO NO MORE. HOOKED IT UP TO THE COMPUTER AND CODES p0302, P0172, P0700,P0562 CAME UP. CHECKED SPARK PLUGS, WIRES, AND THE IGNITION COIL, STILL DIDNT FIX THE PROBLEM. WHEN TRYING TO START THE CAR, ALL IT DOES IS CRANK WONT START.
Old Apr 16, 2016 | 07:56 AM
Turn your caps lock off.
