Clunk noise on drivers side only 2003 Neon SXT
Old Jun 10, 2016 | 10:17 PM
70383roadrunner's Avatar
70383roadrunner
Originally Posted by darthroush
The end links are what secure the ends of the sway bar to the control arms, and by the sounds of it, the same things you replaced. Good to hear the clunk is (mostly) gone!
I'm thinking it might also be that they are polyurethane. Maybe if I replaced then with rubber bushings it might have been better.
Old Jun 14, 2016 | 02:31 PM
darthroush's Avatar
darthroush
Section Moderator
I had poly end links, but never had a noise because of them.
