2005 Neon cutting out and runnnig rough
Old Jul 18, 2016 | 02:25 PM
Tim B's Avatar
Tim B
Default 2005 Neon cutting out and runnnig rough
I bought a used 2005 Neon about 4 month ago. The first 2 months it ran fine but soon after that it started to miss every once in awhile. As time went on it started to happen more often Now every time I get in the car it starts ok but after about 10 to 15 minutes it starts to cut out and will not go over 55 MPH. I have to pull over several times and shut it off after about the 3rd to 4th time it runs fine for the remainder of my hour and a half drive to work. It happens again on my home from work.
I noticed that all three wires in the plug that connects to the coil had been spliced using butt splices that were crimped poorly, I replaced all of the splices but that had no effect. Any suggestion would be great.
Old Jul 19, 2016 | 10:29 AM
TejasMtnBiker's Avatar
TejasMtnBiker
have you changed the plugs, gapped correctly & new plug wires yet?
Old Jul 20, 2016 | 02:38 PM
Tim B's Avatar
Tim B
No I haven't. Was looking for suggestions and a place to start. I will try that this week end but if the plugs were bad why would it start working after awhile? I am not much of a mechanic but if told what to do i can usually figure it out.
Old Jul 20, 2016 | 06:57 PM
TejasMtnBiker
was it throwing any check engine codes by doing the ignition key dance?
Just saying, Plugs an wires are cheap fixes, you pull a plug an the center electrode tips rounded off with almost double the gap required, time to spend a $1.57
Old Jul 21, 2016 | 01:13 PM
Tim B's Avatar
Tim B
The check engine light is on so I am sure if I had it checked out it has stored codes.I will have Auto Zone pull the codes when I get new plugs. Thank You.
Old Aug 1, 2016 | 12:20 PM
Tim B's Avatar
Tim B
Turns out that it was a crank shaft sensor causing the problem. Changed that out and the problem went away.
Old Aug 4, 2016 | 03:04 PM
TejasMtnBiker
awesome! Next will be your cam position sensor up top
