2001 Plymouth Neon
Old Aug 26, 2016 | 04:47 PM
fair67's Avatar
fair67
Default 2001 Plymouth Neon
Would anyone have any idea of why my rear speakers do not work. The front work fine and when I put a test light to the rear speaker wire there is power to them but no sound.
Thanks
Old Aug 26, 2016 | 05:24 PM
Your speakers have power?
Old Aug 27, 2016 | 12:49 AM
fair67's Avatar
fair67
Yes when I put a test light to the rear speakers there is power to them both but no sound.
Old Aug 28, 2016 | 01:18 PM
paw paw's Avatar
paw paw
Did the problem come about suddenly after some event?
Maybe the front/back fader control is biased totally to the front speakers? Set all controls to their center positions & let us know how it goes.
Old Aug 28, 2016 | 03:47 PM
fair67's Avatar
fair67
Controls are in middle and there was no event just stopped working. No sound or even static out of them It is crazy.
Old Aug 28, 2016 | 06:43 PM
paw paw's Avatar
paw paw
Ok, good feedback. Now what happens if you try the CD, ect player, any sound then?
If not, here is a link you can use to look up the wiring to the rear speakers.
http://www.revbase.com/BBBMotor/Wd
Old Aug 29, 2016 | 09:45 AM
TejasMtnBiker's Avatar
TejasMtnBiker
if you have power to the rears did you try a speaker from like a home stereo or boom box laying around? Sometimes the voice coil goes bad like that on oem but seldomly
Old Aug 29, 2016 | 05:06 PM
fair67's Avatar
fair67
I will try and find a speaker and give it a try thanks I will let you know the results.
Old Sep 2, 2016 | 06:56 PM
TejasMtnBiker
you can use a volt meter also instead of a speaker laying around, its a enough to light a 12v bulb dimly that will let you know its working from the head unit
Old Sep 7, 2016 | 03:13 PM
TejasMtnBiker
any luck
