2003 Neon Tranny Problem
Old Nov 12, 2005 | 08:23 PM
Bunyon2005's Avatar
Bunyon2005
Default 2003 Neon Tranny Problem
I have a 2003 Neon Se.....i just recently put a stage 1 clutch in after doin so i found out that my 2nd gear is shot and my 3rd gear is goin....i know i need to get another tranny....but i was wondering if a transmission from a Sxt neon would work for my se neon....? also is there any difference between the 2 tranny's.....?
Old Nov 25, 2005 | 08:32 PM
wtnpowdercoating's Avatar
wtnpowdercoating
Default RE: 2003 Neon Tranny Problem
The SE and SXT will use the same transmission. The R/T uses a different trans which has a different final drive ratio.
Hope that helps you
David
Old Nov 26, 2005 | 04:26 PM
casper's Avatar
casper
Yep the trannys are all the same and the R/T trans will bolt right up.
