Ugrading rims
Old Oct 4, 2016 | 01:34 PM
Myneon's Avatar
Myneon
Question Ugrading rims
Hi everyone thanks for taking the time to make these threads, they've been a lot of help!!
Can i get some help with deciding what tire to put on 16 rims. I bought three Used with 215 55 r16 tires and they won't reach the studs and they touch the strut assembly right under spring plate...
Old Oct 4, 2016 | 01:36 PM
You bought wheels with the wrong offset and backspacing. If they are that far off, even spacers wont help you. They wont fit.
Old Oct 4, 2016 | 02:43 PM
Myneon's Avatar
Myneon
i know i messed up ... that's what i get for rushing into something i'm ignorant about...but there has to be a way cuz the guy that sold them to me said he had them on a neon...
i just installed a set of complete struts, don't know if that would have anything to do with it. they are real close to the studs... plz help..
Old Oct 4, 2016 | 03:10 PM
If the suspension is in the way, they won't fit. Buyer beware. Sellers will tell you anything.
Old Oct 4, 2016 | 03:17 PM
Myneon's Avatar
Myneon
Well thanks for the info anyways...the tire is whats touching the shock....so i thought changing the tire size would obviously make a difference
Old Oct 4, 2016 | 03:45 PM
If the wheel holes wont even touch the studs, changing tire sizes wont make that much difference up.
Old Oct 4, 2016 | 03:46 PM
Myneon's Avatar
Myneon
What info do i need to know in order to buy the right rim
Old Oct 4, 2016 | 03:48 PM
Myneon's Avatar
Myneon
Well what about longer studs???
Old Oct 4, 2016 | 03:50 PM
Myneon's Avatar
Myneon
I know those have to be a specific measurement too. But i can get them longer...
Old Oct 4, 2016 | 03:52 PM
You need to know the offset and backspacing of the stock wheels. Longer studs won't help you if you can't torque the wheel down against the hub since the tire is hitting the strut.
