Timing belt and water pump replacement
Old Oct 12, 2016 | 07:53 PM
tbesse13@gmail.com's Avatar
tbesse13@gmail.com
Default Timing belt and water pump replacement
Ok so I had timing belt and water pump replaced today and now when the cars running there a fairly inconsistent grinding/scraping noise. Shop that did it claims it needs to break in... That sounds like non sense to me. Anyone else experience this?
Old Oct 13, 2016 | 12:02 PM
paw paw's Avatar
paw paw
Had a shop replace my timing belt & wp, flush coolant, replace thermostat & radiator hoses & the serp & alternator belts last year & all was & is quiet afterwards.
SO, were any of your old external belts also replaced?
Did they use a New, or Reman water pump & did they also replace the timing belt idler pulley?
Can you tell us what area of the engine the noise is coming from & if it sounds like it's internal, or external to the engine.
Old Oct 14, 2016 | 05:43 PM
tbesse13@gmail.com
I replaced serp belt not long ago. Alternator belt looked fine. Noise is coming from the passenger side of motor. Replaced timing belt, tensioner pulley and water pump. Brand new gates kit. Motor also shakes a lot now no matter how much I mess with the torque struts
Old Oct 14, 2016 | 05:58 PM
paw paw's Avatar
paw paw
Ok, so the timing belt idler pulley wasn't replaced, so maybe it's bearings belong on the suspect list for the noise.
Seeing as how you say the engine is also shaking, you may have more than one problem.
Is the shake in time with the noise & or do you have a flashing CEL light, that would indicate a cylinder misfire, if so, the engine computer will set a trouble code to indicate which cyl is acting out.
If you have a scan tool, or code reader, have it scan the engine computer for trouble codes & post All code Numbers as they can provide good trouble shooting clues.
If you don't have a scan tool, or code reader & the CEL is lit, or flashing, most auto parts stores will scan for trouble codes at no cost. Write down & post the code Numbers.
Old Oct 17, 2016 | 12:20 PM
bigmike80's Avatar
bigmike80
Sounds bogus to me. When you change the timing belt all should be quiet. You have to remove all 3 of the motor mounts when you change the timing belt on a neon. Maybe your shaking/noise is that they didn't get them back on properly?
Also I dont know exactly which years it does or doesnt work on but i know for a fact it does on my 03, If you need to pull codes without a reader you can turn the key on just as soon as the lights on the dash come on turn the key off. Do this 3-4 times quickly (about half a second on and half a second off) and leave the key on (dont try to start it) and the car will give you the codes on the odometer (they will just say Pxxxx, Pxxxx, done)
Old Oct 22, 2016 | 05:10 PM
tbesse13@gmail.com
No codes. I replaced torque struts and noise is gone but steerining wheel shakes pretty good now. I followed the procedure completely gap from the 2 bolts is right at 4.7 inches. This car really pisses me off sometimes
Old Oct 22, 2016 | 05:31 PM
paw paw's Avatar
paw paw
Consider this vibration analysis flow chart to see if it'll help narrow down the suspects. & let us know how it goes.
https://dodgeforum.com/forum/2nd-gen...low-chart.html
Old Oct 22, 2016 | 11:12 PM
darthroush's Avatar
darthroush
Section Moderator
Were they Dodge or aftermarket mounts? The aftermarket mounts are not fluid filled and create more vibration.
Old Oct 22, 2016 | 11:15 PM
tbesse13@gmail.com
They're anchor brand. I've read mopar is the only way to go so that'll be my next try
Old Oct 23, 2016 | 09:18 PM
tbesse13@gmail.com
I took the torque struts off and redid the alignment procedure. Almost no shake now. Still a slight vibration but not enough to irritate me anymore. Still have the factory center mount and trans mount but anchor brand torque struts. So all is somewhat good... For now
