short throw shifter
Old Nov 14, 2005 | 01:52 AM
james94538's Avatar
james94538
Default short throw shifter
does anyone know if you only need the short throw shifter itself, or are there any more parts required?
Old Nov 14, 2005 | 02:24 AM
BigMac's Avatar
BigMac
Default RE: short throw shifter
All you need is the shifter, unless you want to replace the shifter-cable bushings too (which a lot of people do).
Old Nov 14, 2005 | 02:33 AM
LowSlowNeon's Avatar
LowSlowNeon
What short shifter are you looking at? Some are just the shaft part and others are the entire shifter assembly.
Old Nov 14, 2005 | 03:51 AM
james94538's Avatar
james94538
I was looking at the b&m, the hurst and the mopar assembly which are all about a 120 in price so does anyone know which is better and how hard is it to change the shifter out?
Old Nov 14, 2005 | 04:19 AM
LowSlowNeon
I've got the mopar unit. I really like it. A much improved shift over stock shifter. It is even better with booger bushings installed. I haven't installed a B&M unit on a neon...but I did it on another car and it wasn't real hard to do. Probably took about an hour to do. I don't know anything about the hurst. The mopar unit is easy to install, can be done in about 30 minutes.
Old Nov 15, 2005 | 06:09 PM
james94538's Avatar
james94538
Thanks guys i am gonna get one within the next few weeks i think im gonna go with the mopar shifter its only a couple bucks more and i can keep it as much mopar as possible.
