HELP!! Dodge neon 05 sputtering when accelerating
Old Nov 20, 2016 | 10:32 AM
flanzy's Avatar
flanzy
Default HELP!! Dodge neon 05 sputtering when accelerating
•it has new camshaft and replaced the old one and it's still giving me a camshaft code
• sputters when I accelerate 2000 rpm
• pretty sure it's miss firing
•changed spark plugs but not the wiring
• check engine light is on
Please help!!!
Old Nov 21, 2016 | 03:23 PM
darthroush's Avatar
darthroush
Section Moderator
Did you check the sensor wiring?
Old Nov 26, 2016 | 02:53 PM
paw paw's Avatar
paw paw
Scan the computer for trouble code clues & post All code Numbers, as they can help focus a troubleshoot. If you had a cylinder misfire, the CEL would blink & set a code for the cylinder/s with woes. If the problem is with the cam sensor or it's wiring, you should have a code for it. More thoughts for consideration, let us know what you find.
