2000 neon p windows and p lock problem
Old Nov 16, 2005 | 12:41 AM
benderxr's Avatar
benderxr
Default 2000 neon p windows and p lock problem
the power window and power lock works fine on the driver side but they do not work on the passenger side .would anyone know why ?
Old Nov 16, 2005 | 05:26 PM
GrApHite03's Avatar
GrApHite03
Default RE: 2000 neon p windows and p lock problem
ORIGINAL: benderxr
What does the switch feel like... is it loose? or does it feel normal? I know i've had to take apart my switches on numerous occassions. I'm a smoker and tend to have the window open when its raining. The water will start to rust the pins that make the connection in the switch. once rusted, the pin will not make contact and you window will not work.
I take mine apart and sand down the pins and it will work fine for a while. becareful though... those pins are tiny!!
k3v
