05 neon whats missing in my head gasket set?
I just removed the head, know am looking at a parts list. I found this Felpro HS9036pt2 is this a good set? I may need new valves to, one exhaust valve was bad. It looked like the head gasket had some rust on it????
05 neon 2.0
05 neon 2.0
HS9036 pt-2 gasket set would you know what these 5 gaskets are for?
https://www.oreillyauto.com/detail/f...004/dodge/neon
On the bottom line of gaskets, from left to right I'm looking at the 3rd,4th,8th,9th and 10th. The 3rd one is about three inches wide and real heavy must be for the exhaust ?, mine doesn't have that. Number 4 is about 1- 1/4" wide 1/4" thick, blue. Number 8 is about 1" wide and thin,9 and 10 are about 1/2" wide and thin.
Thanks
Thanks
