Won't start again
Won't start again
My 2000 Neon ES 2.0L didn't start last week. Bought a new battery and cleaned cables, worked for a couple of days. Ran an errand, about 7 miles, would not start nor take a jump. Next morning it started right up. Drove it home, turned it off, would not start. Couple of hours it started. Any suggestions?
I'm having the same issue with my 1998 B2500 5.9L as it will not crank but all gauges and system lights function with the ignition switch. So far, I have checked all fuse, relay and replaced the starter/solenoid and neutral safety switch. Can jump start the engine with key on and thru the starter relay port with a power probe.
Reading this fellows post and the noise he heard leads me back to a symptom noise that has been present for awhile but did not effect operation until possibly now. I've noticed that symptom as a "buzzing" under the dash and seem close. Is there another relay under the dash perhaps, that I'm not seeing in ALLDATADIY ? Sadly, I have a OEM service manual but have recently moved and a warehouse full of hard to access boxes, otherwise it was always good for troubleshooting etc.
Thank you for considering my question here and would truly appreciate some experienced advice or suggestions! On my original thread one fellow mentioned one of the 3 grounds maybe a culprit?
About a year ago I had the exact same issue. It was the starter. Also clean the OTHER end of those cables if you haven't, couldn't hurt.
And if you don't already know, if you can get someone to gently tap on the starter with a hammer while you crank it, sometimes it will work temporarily.
