2000 Neon A/C
Old Aug 20, 2017 | 01:27 PM
fair67's Avatar
fair67
Default 2000 Neon A/C
Hello
I got a 2000 neon and the Air has worked great. Now it just blows warm air I am pretty sure it is full of 134 and I checked the fuse under the hood. Also the blower motor works and the fuse is good in the dash and Ideas.
Thanks
Old Aug 20, 2017 | 03:29 PM
How are you pretty sure it's full of R-134?
Old Aug 20, 2017 | 05:04 PM
fair67's Avatar
fair67
I filled it and have guages it is in green.
Old Aug 20, 2017 | 05:28 PM
fair67's Avatar
fair67
The compressor is not kicking on.
Old Aug 20, 2017 | 06:07 PM
Jump the low side pressure switch and see if the compressor cones on.
Old Aug 20, 2017 | 06:30 PM
fair67's Avatar
fair67
Where is the low side pressure switch? Thanks
Old Aug 20, 2017 | 07:20 PM
fair67's Avatar
fair67
I think I found it by the firewall on the square block that bolts to the evaporator. I took the wire off and jumped it with no compressor going on . Also should there be power to that wire I did not get any with my test light.
Old Aug 27, 2017 | 10:55 AM
fair67's Avatar
fair67
I think the compressor is bad,
