Need info about motor mount bushing kit
Old Sep 17, 2017 | 04:33 PM
mike L's Avatar
mike L
Default Need info about motor mount bushing kit
My upper motor mount 5085122ab rubber shows cracks. Should I bother trying to replace just the bushing to save money? How hard is it to remove the and install the bushing ? Where can I find a kit that will last?
ps I already replaced the middle motor mount.
Old Sep 17, 2017 | 06:58 PM
darthroush's Avatar
darthroush
Section Moderator
If you're asking about replacing just the rubber part, you can't. It's a whole unit.
Old Sep 18, 2017 | 09:07 AM
mike L's Avatar
mike L
I saw one bushing kit for sale online. Also a you tube video taking about replacing them.
Old Sep 18, 2017 | 07:53 PM
darthroush's Avatar
darthroush
Section Moderator
The inserts?
Old Sep 19, 2017 | 02:37 PM
mike L's Avatar
mike L
Default upper motor mounts inserts
Originally Posted by darthroush
The inserts?
Which way do most people go with inserts or a new upper motor mount? Whats the difference in price? Do you have to cut out the rubber bushing to install theses?
Old Sep 19, 2017 | 07:08 PM
darthroush's Avatar
darthroush
Section Moderator
If the mount is broken, it needs to be replaced before the inserts are used. You might have to trim rubber flashing in the mounts to fit the inserts in, but they are simply that: inserts. They are not replacements for the mount and are not meant to "fix" a broken mount.
