Thanks you for help with my 05 neon timimg belt and head replacement
Old Oct 13, 2017 | 05:38 PM
mike L's Avatar
mike L
Default Thanks you for help with my 05 neon timimg belt and head replacement
I had a missing cylinder # 2 trouble code. I had only had about 75 psi compression it was a burnt valve.
I checked the compression now and I get 185psi on each cylinder. The rebuilt head from Advance A it didn't look like it had any assembly lube when it was rebuilt. It was cleaned very well and oiled every where! Only some valves were replaced the other were tested and it was decked you could see the swirls markings. It was painted gray, some did start to peel off under the valve cover gasket. The timing belt was a half tooth off because it was decked. I could not contact the company buy phone, no number on there web site. Only email which they never replayed, I checked my junked mailed to .
Old Oct 25, 2017 | 12:22 AM
paw paw's Avatar
paw paw
OK, good feedback & to hear you persevered & got this puppy back together & on the road again.
