2000 neon
Hey guys, I have a 2000 neon that I am having a problem with & I'm hoping someone car help out. The car runs fine at an idle but when I start to drive it the RPMs go up & down causing the car to jerk back & forth. But if I start out really slow I can get up to speed & I'm fine as long as I stay there. It is not throwing a code at all. But I have replaced the fuel pump, coil pack & TPS. I have checked for vacuum leaks and I checked the injectors. What is throwing me off is the no check engine light. Any body have any ideas?
